Timing belt 2.5d 1991
benji83
fiat ducato 2.5d 91
Hi all .. I have a 1991 fiat ducato .
The timing belt keeps jumping on the fuel pump every few hundred miles has anybody had this problem ?
For it to slip it is either worn, loose or the pump pulley is worn/out of alignment. Replace the belt and check it all.
Should it slip between crankshaft and cam shaft you may well be in for a new engine.
