Thule Omnistep Motor?
Bridgend, South Wales
Just started!
Over this weekend I spent sometime trying to get the Omnistep to work, although 12v is switched to the terminals on the motor - not a hint of action :unsure: If I press the switch to retract the step 12v is supplied to one of the terminals and similarly pressing the switch to extend, so it doesn't seem to be a power issue. I'm assuming the motor/step metalwork provides the earth.
So I removed the motor, a BOSCH 0 130 821 603 Electric Motor :)
I connected a 12v supply to each of the terminals in turn with an earth connection to the metal body - again, nothing!
So, unless I'm being a complete idiot and doing something wrong I'm at the point of considering a replacement motor! Any suggestions?
BTW, no buzzer that I could see.
Have a very good look at the metal frame of the step mechanism. Look for any points where wear and tear may have ocurred to the extent that the step is over-extending to a point where the motor can't move it. If that is the case, manual assistance might shift it, and if you can find someone to build up where the wear is with weld, that'll sort it hopefully.
Next step would be to look at the brushes in the motor and see if you can find replacements if they are worn down.
The motor seems to be the same as a left hand window winder for a 1997 Volvo 900 series ....
To test you apply the 12v across the contacts, and reverse the polarity to make it go the other - not to the motor body
When I stripped mine I found that the main axle on the gearbox was seized, so I clean and greased everything back up and it's been working fine ever since.
Thanks for the replies guys :)
Trevor Wbm
Had a good look at the step mechanism and although old, it seems in reasonable condition, as soon as I removed the circlip and the square drive shaft from the step assembly the step just dropped down under its own weight :)
Trevor Wbm & Bobby-gg
My next plan is to disassemble the motor as I have nothing to lose. I can't turn the shaft at all, not even with a pair of pliers so this might be a possible problem.
Thanks for the suggestions, anything's better than spending money :)
It was posted here a few weeks back that this is the same motor but a lot cheaper than if bought from Thule. Take a peek!
Trevor Wbm
You won't be able to turn the shaft as its a worm drive motor, the motor locks the output shaft.
Once you strip it down, you'll see how it works, but try voltage onto it again
Just stripped it down and can clearly see why I wouldn't be able to turn the shaft - the gearing is very very low and needs the high speed of the worm drive to turn the shaft.
I oiled it up and freed any stiffness but will have to buy some grease before I completely reassemble it. I did connect 12v but no sign of life! My feeling is the brushes are to badly worn:
Will try and remove them tomorrow and clean up etc
Will check this out, thanks :) Have to ensure the drive is square etc. It's a different part number I need 0 130 821 603 the Ebay advert shows 0 390 203 266
Yes, those brushes have had their day.
Geoff
