Thule electric step problem on 2019 Autotrail imala.
elddis sunseeker EL
Our electric step stopped working on the switch. We 40d it and it worked for 2 weeks. Now stopped working again.
Fuses behind seat ok. Can’t find a dedicated fuse or trip anywhere in documents?
Any suggestions for a fix?
Solution2
I do not know if it will help but there is a diagram for the Thule omnistep in the Resources section (at the bottom of this page) , Motorhome technical articles , page 2 , which shows a fuse near the leisure battery.
Solution
Hi Geoff found the fuses near leisure battery but all are ok and still no step but thanks for trying to help.
direct wire the relay under the seat near the door to check if the relay has gone
Sounds like I need an electrician? What you suggest is a bit beyond my skill set but I can pass the advice to my fixer when I get back to uk in 3 weeks.
if you have a voltmeter try this . The same relay controls a fridge light function too on the imala, check all the fridge controls are working
