- Oct 21, 2023
- 5
- 3
- Adria Twin SGX
- Adria our 1st mainstream PVC
No definitely not the door seal they had a camera in and condensation was visibleI have a SLB. No condensation there on mine. Could it be rear door seal?
There's no doubt it would be damp back there. But if the door seal leaked, wouldn't that also cause condensation?No definitely not the door seal they had a camera in and condensation was visible
This was the van roof on a frosty morning with the heating set at 5degs to try identify the lack of insulation all across the back crossmember (no people in the van)If they have identified condensation with a camera surely the fault lies in the conversion?
Whenever I have looked at PVC conversions on the internet ( I toyed with the idea) the provision of adequate insulation is always emphasised in order to minimise condensation.
As its well known surely it’s the fault of the converter? Surely they insulate? How much more have they missed?
Whilst they have attempted to cure the condensation at source I would have thought they should strip it down and replace the wall coverings.
That will at least enable you to monitor any fresh stains.
This was the van roof on a frosty morning with the heating set at 5degs to try identify the lack of insulation all across the back crossmember (no people in the van)View attachment 858559
The insulation in a Murvi is just cheap 2 bit thin loft insulation though with no vapour barrier. However, I took the panel off in the wardrobe and the insulation behind was still perfect and dry as a bone.I do not want to 'Big up' the brand BUT, in my 6yrs of ownership of my 2007 Murvi Morello PVC I have never had problems with condensation and never read about it from other owners!
The side body windows are all double glazed.
90% of inside, including ceiling, is covered by a thin carpet like material.
Not sure what they are doing right, but if they can do it, so can others.
Yes, they maybe more expensive than others one the market, but I suppose one gets what one pays for?
IMO, from the pictures, that's not condensation, that's water ingress.
Yes, warm carries more moisture and the ventilation carries the warm (moist) aiir out of the vehicle.Not a good idea to use heat to dry it, out as warm air carries more moisture than cold air.
