When you do a self build. I can attest to that.
I have just spent the day stripping out all the wardrobes and boiler cupboards ready for a refit tomorrow. Gone is the cupboard with 3 shelves. The massive hole where the fridge should have been and a single lift up cupboard. Also gone is the horrible front panels and doors for the boiler area.
All done in a horrible mix of the plastic coated MDF sheets and pine lats and ply. Built using the plastic blocks favoured by motorhome manufacturers.
Tomorrow if everything goes to plan I will end up with 6 Large Drawers, a compact space for my fridge and a custom space for my computer. All made with solid 18mm ply using pocket holes and PU foam glue. It is rock solid enough that I could climb on it to reach stuff yesterday.
I am redoing this as storage was a problem for me as a fulltimer and the sage advice of @JJ was you can't have too many drawers. Yes JJ, I do listen to you
The new unit is a touch wider so the table area has to be redone and the safe box has to be rebuilt.
Also as the unit is totally different and I have new toys to install I will be doing a full rewire while I am at it as well.....
Because I am a fulltimer I have to do this at the side of the road using battery power tools while living in it at the same time. This has raised the challenge quotient somewhat as each night I have to take the new unit to pieces and flat pack it back into the van... I will be glad to get it finished just in time to start the next project...
