Thanks for your reply.Error code 6 = DC high voltage is out of range (lower than 10v or higher than 15v). There may be a 20amp fuse near the starter battery that has blown. (causing lower than 10v)
Most, if not all newer vans won't run on battery only without the engine running, AFAIK.Generally you should only run on 12v with the engine on as you will rapidly deplete the habitation battery otherwise.
The model number is EBL 30 .The fuse I mean is a 20 amp one (not a 50 amp) that could be near the engine starter battery ,(but may be elsewhere). If you have a Schaudt electroblock EBL do you know the model number ?
It is also possible that there is a poor 12v connection at the rear of the fridge that you may be able to check if you remove the lower fridge vent cover
If there is not a Motorhome workshop/mobiIe service near you is there a Caravan workshop near you that may be able to check the wiring connections out for you as the fridge is the same as fitted in a Caravan.
The fridge itself , if faulty , may still be under warranty ?
Its a 2020 Hymer.What van? Usually, on Ducato cab the fuse will be on a floating loom alongside the starter battery under the panel beneath the passengers foot space. Why it's blown will be the issue
Mike.
I have tried it whilst the engine is running, thanks.Most, if not all newer vans won't run on battery only without the engine running, AFAIK.
Mike.
Many thanks for this info. I shall take a look and let you know.Hymer definitely fit a separate 20a in the starter battery compartment for the fridge feed. It will be clipped in next to the main 50a feed to the EBL.
This fuse also takes the feed from any solar regulator to the starter battery so you may notice the it isn’t being topped up either.
HTH
Chris
Yes, its a Mercedes based Hymer. Many thanks for the other repair shop options.Have you found a separate 20 amp fuse near the starter battery ? It could also be in a small fuse/relay module marked PLT2 that may be near the EBL .
Is your 2020 Hymer Mercedes based ? as it may be different wiring set up to a Fiat based one.
For repair if you can travel you could try www.reliancecms.uk or www.sunstore.co.uk both have Motorhome repair workshops
Solar all appears in order to me...Hymer definitely fit a separate 20a in the starter battery compartment for the fridge feed. It will be clipped in next to the main 50a feed to the EBL.
HTH
Chris
The reference to the 20A fridge fuse by the starter battery is that the wire works both ways - trickle charging the starter battery from the solar (a few amps) but supplying 14Aor so to the fridge when the engine is running. So yes you clearly have solar panels that are working from the screenshot but you don't know if that is getting to the starter battery from the solar controller via the EBL. When it's sunny with the engine off if the starter battery voltage is a charging voltage (14v or so) then that wire and fuse are intact .Solar all appears in order to me...
Many thanks for explaining that.The reference to the 20A fridge fuse by the starter battery is that the wire works both ways - trickle charging the starter battery from the solar (a few amps) but supplying 14Aor so to the fridge when the engine is running. So yes you clearly have solar panels that are working from the screenshot but you don't know if that is getting to the starter battery from the solar controller via the EBL. When it's sunny with the engine off if the starter battery voltage is a charging voltage (14v or so) then that wire and fuse are intact .
Not to worry, the " I no nothing".club has a healthy membershipMany thanks for explaining that.
As you can probably tell, I have very little understanding of anything electrical.
