Have you checked that the switch is level. Sometimes they stick.
Yeah, we tried the hairdryer with our 12v adapter but i think it tripped something. Immediately turned off and now none of our power points will deliver power :/You could try warming the switch up with a hair drier and dry out the switch.
My guess is the water is jumping the two contacts.
you will probably find the connections are spade connectors.
@Debs had what sounds like the same, on hers the two wires feeding the switch were somehow arcing together, I gently pushed them apart up behind the cupboard and stopped it, not sure how permanent the fix was but think it at least sorted the problem overnight
depending on the connection, if you can reach the back of the switch, pulling off one of the wires might stop it as well, but wont work if soldered on
