Does the pump make a noise?My water has stopped coming out of the taps. I've filled the water tank up and it is showing as full. Does that mean the water pump is broken? Is there anything I can check/do?
Is the pump making an noise? Had the pipes been emptied before the tank was filled?My water has stopped coming out of the taps. I've filled the water tank up and it is showing as full. Does that mean the water pump is broken? Is there anything I can check/do?
Can you see the power feed to the pump? Can you post a photo?The fuse is okay. I have a multimeter but don't know where to put it. The pump is the trumatic item that has the dump valve on right? That sits next to the boiler...
You may have a submersible pump in which case it will be in the water tankThe fuse is okay. I have a multimeter but don't know where to put it. The pump is the trumatic item that has the dump valve on right? That sits next to the boiler...
That is the supply to the pump. Which wire blue/brown should I put the meter red wire on, and which blue/brown should I put the meter black line on?on the top of you tank there is a white cable with a blue and brown wire inside that go to the connector. This looks to me to be the supply to the pump.
If it is shove your meter across those two connections and operate a tap and see if you get 12v
Doesn't really matter I think as you would get a reading of 12v or -12v if there is power but normally blue to black.That is the supply to the pump. Which wire blue/brown should I put the meter red wire on, and which blue/brown should I put the meter black line on?
It doesn't matter which because if the probes are the 'wrong' way round you'll just get a minus sign in front of the voltage displayed on a meter with a digital screen. If you swap your probes over you'll still get the voltage reading but without the minus sign.That is the supply to the pump. Which wire blue/brown should I put the meter red wire on, and which blue/brown should I put the meter black line on?
