ok, Got an update for you.I was just curious really.
I was thinking you might have trouble holding the part to tap the thread into it as that HDPE is quite slippy and very soft, but if you get them welded into the bigger sheet first it should be no problem apart from the physical size of getting it under your drill press or what have you, as you've already mentioned.
I've got a component made from 20mm thick 4140 steel that needs welding for an M20 thread repair, just waiting on Amazon dropping off the fine pitch tap this afternoon, then I need the wife to go out while I preheat the whole thing in the kitchen oven !
Just saw the bit about getting rid of the wife so you can abuse the kitchen. Love itI was just curious really.
It went in really easily to be honest. I think the pictures are a bit deceptive. There is quite a few thread worth of taper.Gromett
If it were me I would get the large tap ground down a bit more at the end for an easier start.
You can pick up pillar drills cheap secound hand.
It doesn’t even need to work![]()
When I say I tapped it with a lump hammer I was perhaps over egging it a little![]()
