Table req!!!
Taunton, Somerset
Starting to understand
Hi all, i have a Sun Living PVC & the inside table is mahooosive & heavy, so as it's only me i need a smaller table. So having a look at the show in Shepton Mallett today saw loads of tables that would suit all on new motors. Does anybody have ideas where i can source one, i.e. companies they have used. Many thanks. ken
Try Nisbets catering, fantastic quality, not your usual chipboard with stuck on plastic edge and no more expensive than others. Good range of sizes and colours.
Very pleased with ours.
Got our small one which we replaced out huge table with at the Irish chaps marquee at one of the shows. Name escapes me Murphy or O'Malley or something.
O'Leary - they have a website. There are a lot of caravan/mh tables on eBay too.
Funny enough I picked up a nice little round table with fiamma leg and tripod. Cost a fortune, all of £4 in a charity shop
Can you cut it down to the size you want?
I researched this long and hard before buying what I consider to be the best table top available. I looked at all sorts of caravan tables, self-build table tops on ebay, O’Leary’s and almost gave up, then I found these cafe table tops sold by Cafereality.
They have a fantastic collection of tops in all sorts of patterns and designs, two tones, single colour, and as they are for commercial use you won't have them falling apart or getting a hole in the top when you drop a can of beans on it.
They come round, square or oblong in several sizes, so something to suit every application.
I bought the WERZALIT VIVO DEEP BLUE 338
Product Code: WERZTTV8
Durable cafe table top that is available in a variety of size options and is available for a free UK mainland delivery service.
Deep royal blue colour
Available in a variety of sizes
Special design with no joins
Can be used indoors and outdoors
Manufactured in Germany
UV resistant
Ideal for serving hot meals on
Quick and easy cleaning
Produced in Europe
Have been asked by several people about it and for a picture of the underside, so here it is..
http://www.cafereality.co.uk/cat/cafe-tables/table-tops-1
and the leg
http://www.grasshopperleisure.co.uk/stainless-steel-island-table-leg-set---range-of-sizes-3665-p.asp
We got a small wooden one from Argos, was only about £7
Broken Link Removed
Another vote for Rainbow. Ours is fitted on a swing out arm with the table top offset so it can be adjusted to multiple positions. (y)
One thing I did find out about with tables is the light ones get easily damaged. I bought a Rainbow one for our Laika and dropped an iPhone on it. This put a small noticeable hole in it. The Formica tops are not that resilient to damage it’s whats underneath that gives the Formica it’s strength. Had one made to size buy local kitchen worktop supplier. It’s a bit heavy because of its 30mm thickness but it sure is tough. With a smaller top you would probably not notice. Cost was £90 and I got a choice of colours from their vast range of off cuts.
see my post above.. proper commercial cafe table tops, moulded bases, so impervious to water and also burn proof..
which are cheaper, lighter and can be used outside . Quality from Germany
@scotjimland
Which size is the table? I'm quite tempted as yours looks great and my seat layout looks the same.
The site says 15-20 working day delivery is that accurate?
Rob
We had a huge permanent pedestal table in our Burstner which was removed on day 1 and has lived in the garage at home ever since. As we have no need of a permanent table, we now use generic camping tables which can be stowed easily, typically a very lightweight folding table (from Regatta?) or sometimes a slightly bigger/heavier bamboo table as required.
@scotjimland
Rob
Hi Rob..
I bought the 600mm diameter , which was just right for seating two people and the right size to store in the wardrobe
If I recall correctly delivery was less then two weeks..
Edit.. just remembered, I cut out a 600mm diameter bit of plywood to test it for size..
