t 66 sunlight
t 66 sunlight
hello
I bought a second-hand t66 sunlight and all the electrical outlets in the cell do not work when the engine is off.
I tested the fuses everything is ok.
do you have an idea for me?
thank you
Jean Marc
when i plug 230v all sockets work .
but when i'm not connected all sockets dont work : (
sorry for my english im french : )
230v sockets normally only work when the motorhome is plugged into a hook-up.
230v appliances can be made to work from batteries. But you need an inverter. High power mains appliances such as toasters, hair dryers and coffee machines need a lot of current. This needs an expensive inverter (preferably a 2kW model with sine wave output). You generally need at least 2 habitation batteries to cope with the high amps the inverter will use.
If you want to use the same sockets that you use for 230v as when you're plugged in, you also need a switchover to select between hook-up power and inverter power. Or you can just plug directly into the inverter.
i will check for a inverter
thanks for you fast response
