Hi All!
Have read up on quite a few different posts but I have a problem that is as yet unsolved.
Thule Steps on our Swift had a little accident and got buckled.
We’ve straightened them out but now they won’t go down,no sound when switch is pressed.
Through the process of elimination, we’ve….
Replaced the switch which is working fine.
Checked the fuses under the bonnet and found one blown,since replaced.
Checked the relay which is fine.
Steps will come down if hooked up to an external battery & go back up when ignition is turned on so motor is working fine.
It’s the internal switch which is showing no sign of life.
Have cleaned and checked all the contacts & they all seem ok.
Would anyone be able to point me in the direction of where to look next?
Thanks in advance
Thanks in advance
