Hi I’ve a swift Kon tiki 894 2022 and have lost the fresh water pipe from my tank does anyone know the size and where I can get a new one it looks slightly larger than a 28mm gutted it fell off
Think it’s 25 mm Dura pipe,or abs pipe which can only be purchased in 5. Meter lengths.
I had the same problem . Kontiki 2020.
The fitting that goes into the tank is 1” bsp so I took it out and put in a plug if in the rare occasion I want to drain the tank I just run the tap..
Or you could put a 1” to 22 mm coupling in both ends and use 22 mm domestic plumbing pipe
To connect between tank and valve. Good luck..
We had a 597 Bessacarr and the water pipe was really low, often knocked it off ! So I took it off the bracket that suspended the outlet valve cut it down by an Inch and it was never a problem again.
