Swift 2019 Dometic 3-way
Just looking
Hi all,
I'm a newbie who is going away in his (new to me) MH this weekend and have documentation for most things other than my fridge.
I have a couple of questions if anyone can please help.
1) what model fridge do I have? Bizarely, I can't see any identifying model number on the unit
2) if I'm just running it between gas and vehicle battery, when I turn off the gas - as I believe is recommended when on the move - if set to auto it'll automatically switch to battery? and then back to gas when I park up and switch gas on?
Thanks all!
It will not switch to battery just because you turn off the gas, it should be wired to only use battery on auto when the engine is running, then it will change from gas or mains to battery when you start the engine
Hope that helps
Edit - it looks like the model label is behind the lower drawer, that’s where ours is, I think it can just be seen in the photo
Reactions: KD
Hope that helps
yup, sorry, did mean to say when running engine. thanks!
now if only I could find out what model I have ...
Thank you so much all, really appreciate! Clearly I need to pay more attention when. looking next time!
