Swapping number plates on a Carthago (front in a holder)
South Yorkshire, UK
Carthago E line 50 D
Any body know how to swap the number plate on the front of a Carthago, as it is in a flimsy and I don't want to break it?
If its like a black one that I have on my Citroen C1 toad I use a thin object like a key at one end to prise the number plate out a little then do the same at the other end whilst keeping the other end out and it will then lift out. The base is spring loaded so that when you put a number plate in you press it down and push it in so that it pops up behind the plastic that holds it in place. My number plates also have 2 lateral holes which can also help ensure that the replacing the number plate it rises up behind the plastic catches to hold it in place.
Sussed it, the middle of the bottom pulls down, then you have to jiggle the number plate into it, a bit fiddly but fairly easy
