Surge damper
Wilmslow, UK
2020 Bessacarr 597
Just arrived at Chester Fairoaks. Set up, water pump on. Water all over the floor at some rate. Surge damper must have gone over winter as I could pull the top off with very little effort. Wardens gave me some no more nails to stick it on as a temp fix. Ordered new one off Amazon. Maybe worth giving it an inspection if you’ve not to avoid what we just experienced. Never even considered checking it. Also; although I’ll empty the fresh water and not turn the pump on, anyone know if I need to drain the boiler to fit the new one. Just a push fit from the look of it
I’m sure someone that knows your van will come along soon. I would have thought that as long as there isn’t a head of water from the boiler then you should be good with just depressurising the system and using a towel for the spill. I would leave all taps closed after depressurisng the system to avoid the head of water dumping on your floor though. If you feel there’s a chance of that then I’d drain down.
There will be quite a bit of water above the level of the damper, so I would just open the drain and all taps first.
Geoff
Thanks for all the replies. All helped. New one fitted (£34). Simple push fit and all seems ok now. It was under the bench seat and leaked out lots of water before I located where it was coming from. Only happened when pump was switched on. Another lesson learned😊👍
