- Apr 13, 2019
- 545
- 1,288
- Burstner 747-2
- since 2010
Hi thank you the nearest pump they have is themaybe Milton Keynes
The Caravan Accessory Store - Big White Box - Milton Keynes
The Caravan Accessory Store - Big White Box Motorhome, Camping & Caravan Accessories at amazing prices based in Milton Keynes. Click on thebigwhitebox.co.uk
Cheers will try them in the morningThese may be able to help
Caravan & Motorhome Servicing Workshop in Ringwood, New Forest
A caravan & motorhome servicing workshop in Ringwood. Offering caravan repairs and installations in the New Forest on the Hamsphire & Dorset border.propexheatsource.co.uk
I’ve put another suggestion on my post but not sure it would be close to youCheers will try them in the morning
Thanks have tried that, the impellor is turning by hand but nothing going on the electrics, I have tested up to the the supply and the whale pump I have replaced it with is working fine.Get you hand in the tank and give the pump a good whack or two on the tank wall with the pump turned on.
No guarantee but the pump impeller/s could be stuck if it hasn't been used for a while
These guys are delivering to the campsite for me to collect. Again thanks for your helpThese guys are showing as one in stock and are located near the M3 and the A303 between Basingstoke and Winchester.
Reich Submersible Water Pump 19 Litres Per Minute
Product Features: 1.4 Bar Fresh Water Pump 19 Litres Per Minute Non-Return Valve Fitted.www.autoleisure.co.uk
Too true this is a great forum for advice on many issues.Absolutely, this forum has helped and advised so many people, glad to be a member. Love you all
Thank you Brains, I have already ordered another, and a spare whale just in case. My system needs a positive supply to the hot water and heating to work on electric, gas will work for heating only without. Having tested the system a couple of weeks ago everything was ok. Then at the last minute a failure. I appreciate your advice and will (as i usually do) carry a spare.There is a shortage of these pumps at the moment.
I ordered one before Xmas, it's due in this week, although not seen any indication that it will arrive yet.
Luckily I had a spare already, so I'm not in a hurry.
Catpirate I would strongly recommend you order another one as a spare, complete with connector plugs and sockets. You will need it one day, as these pumps only seem to have a 3-4 year life.
(My 5 year old van is now on it's third one)
Can you give it to me now, my need is greater than yours LOLOurs went into limp mode a couple of weeks ago.
I gave it a hearty thump or several on the side of the tank.
It didn't immediately correct but I must have dislodged something because a couple of hours later, normal service was resumed.
Lucky?
Couldn't buy a lottery ticket.
These pumps have twin chambers.Ours went into limp mode a couple of weeks ago.
Lucky?
