- Jan 31, 2016
- 2,082
- 3,786
- Hymer B534 DL (2017)
- Well travelled
If you have 200ah batteries, does that mean , in simple terms...you can draw 200amps for 1 hour?
It depends on the battery type - possibly for a Lithium, no chance for anything with lead in it...If you have 200ah batteries, does that mean , in simple terms...you can draw 200amps for 1 hour?
Yes.If you have 200ah batteries, does that mean , in simple terms...you can draw 200amps for 1 hour?
In theory yes, orIf you have 200ah batteries, does that mean , in simple terms...you can draw 200amps for 1 hour?
In theory yes, or
100 amps 2 hours
50 amps 4 hours
25 amps 8 hours
12.5 amps 16 hours
6.25 amps 32 hours
3.125 amps 64 hours
It would be some cable to take 200A! About 35mm if my maths is right. A Busbar job.
If you look at the small print you will find that it's specified for a number of hours. Usually 20 hours. So yes, you can draw 10 amps for 20 hours, and then the battery would be completely flat. That's what the battery manufacturers did to arrive at that 200Ah number.If you have 200ah batteries, does that mean , in simple terms...you can draw 200amps for 1 hour?
