- Feb 13, 2025
- 47
- 53
- Don't own one yet
Hi Funsters,
I've just been reading several threads generally, via google (i.e. not here), about PVC & coachbuilt vehicles regarding the difference in their structures.
Some people say that a PVC vehicle is a PVC construction with insulation foam (PET), sandwiched between two sheets of PVC.
I thought in this context, PVC simply means 'panel van conversion'.
Anyhow, the structure of the PVC was explained but not that of the coachbuilt variety.
So, given that I am planning the build of a MH, with the best possible structure my question is:-
QUESTION: what is the normal structure of the roof, walls and floor of a coachbuilt motorhome?
As for my build; I have considered GRP outside with 40mm - 50mm foam sandwiched between that GRP and an internal (BS standard) marine plywood.
I have set a brief so I can try to follow it.
In case it is of interest to others here it is.
When finished:-
1. The outside should have the appearance of any other high-end motorhome.
2. The roof should not sag, regardless of any reasonable weight on it.
That could be two maintenance operatives in addition to the panels and other normal MH equipment, to be seen on roofs.
The roof should have additional insulation (over the amount in the walls), due to the fact that heat rises.
The roof should be able to cope with various ceiling trims being screwed bolted or stuck to it.
The overall thickness must be within the tolerances of skylights and other roof fittings' maximums.
3. The walls should have enough insulation to resist heat transfer both, to maintain heat and to repel hot summer sun.
The walls should be of sufficient structural integrity, to accommodate the weight of wall cupboards and other items screwed, bolted or sikaflexed to it.
The walls should be no thicker than the maximum set out in the windows and habitation doors' specification.
4. The floor should be robust to prevent road debris from damaging it.
It should also have sufficient insulation properties and a suitable surface to cope with wear and tear.
It should also be able to facilitate/support the installation of hatches for extra storage and underfloor access.
So, the materials I am considering are:- (numbered, relatively, to the points above)
1. GRP or other composite furface with or without gel-coat.
2. The roof to comprise three layers:-
a. 50mm PET sandwiched between GRP.
b. Alloy 'joists', running across the roof, bolted through that 50mm foam, into the alloy frame that runs along the side of the roof.
(That may require sleeving on the bolts, to prevent the crushing of 50mm foam board).
c. A further 50mm foam insulation sheeting, sculpted around the joists, such that there's minimal gap between both sheets of foam.
d. 15mm marine plywood (to BS standard) bolted through that inner 50mm foam insulation board into the joists. This also may require sleeving.
3. The walls shall comprise two layers
b. 18mm marine Plywood (to BS standard)
4. The floor shall comprise several layers:-
a. An aluminium base layer
b. 50mm PET sheeting
c. further PET foam sheeting of 20mm(to accommodate channelling for underfloor heating),
d. 18mm marine plywood to BS standard.
(the 20mm insulation foam will enable mistakes to be made, without wrecking the main 50mm under-floor insulation).
(The marine playwood at 18mm should be adequate to support hatches for underfloor access).
When finished:-
