Strange Tools
Steve and Denise
Spalding LINCS
A Class Carthago
Since 2008
A friend is clearing his Fathers shed out and came across this can any one shed any light as to what is for
The mysterious object –
Total length 152.4mm. The breakdown -
Top section, 2 flat faces, dia 34.75mm, 14mm tall
Upper section 35.3mm dia, 47.5mm tall
Flared out, ~17mm tall
Knurled ring, 47.6mm dia, 13.mm tall
Flared down ~34mm tall
Bottom section, 35.6mm dia, 25.2mm tall.
Inside, from bottom it is for the first ~35mm
Max internal depth is ~106mm.
Thread is 1.75 metric, according to my limited set of thread gauges.
Is it spring loaded?
Is it threaded internally from/at both ends?
Could it be some kind of puller?
If the threaded end has the two flats I would suggest its an elaborate stud extractor.
It is possible that it is a work piece that he did as an apprentice machinist.
Thee two flats are on the other end like a cap but all one part. I feel the knurled ring was to assist screwing it up quickly the nip it up with the two flats on the end.
Looks like a left handed kerfuffle pin extractor, seen 'em loads of times.! :whistle:
It looks like a collet from a milling machine to me.
I was just going to say that. But most of the ones I have seen have splits in them and only threaded internally at one end, unless it is a tool holder?
Going by the dimensions, I'm gonna say it's actually sized in Imperial measurements. It looks kind of familiar, I've used something like it for fitting bearings and oil seals. Maybe @Enword or @Jaws might have an idea ?
That would make good sense as to hold a cutting wheel ?
Usually the miller 'head' is designed to take different adaptations depending on the cutting tool used.
I suspect if this is one then the cutting tool screws into the thread.
The split collet type would look similar but without the internal thread.
Whatever you do don't twist it as it is in fact a 'neutron-electroplasmic wand'. Careless usage can inadvertently cause waste water to be released, solar panels to malfunction, batteries to discharge and a-frames to disengage.
is the internal thread a normal thread or left handed..?
Light Sabre. Does it have 'O W Kenobi' etched on it?
Its a sonic screwdriver as used by Dr Who surely you must be able to see that?
It looks specifically made, in a tool shop for a jig.... it would be helpfull to know where the father worked and what he did.
We made lots of these type of tools for specific jobs on small production lines...
You beat me to it pappajohn.
Looks like an internal measurement tool....
Wind it out till it touches the sides, then measure exact with external micrometer (y)
He was a hoarder of many things but I will ask the question at the weekend when I see him in the pub.
i doubt its home made with a cardboard box
