- Sep 29, 2007
- 911
- 1,598
- C Class
- Motorhoming since 2006, 30 years tent camping in Africa
Hoping someone may have experienced this problem to save us some investigation time.
Someone came in with an Adria that has a EBL227 and Schaudt booster.
During a hab check it was discovered that his starter battery is reported by the control panel to be over 20v.
We checked the starter battery - normal voltage of 12.7-ish
Checked where the starter cable comes into the back of the EBL227 - it’s around 25v
Checked where the starter cable comes into the booster - around 25v
We disconnected the starter battery cable from the back of the EBL, checked that cable and it’s 12.7-ish. The starter battery in the control panel slowly coming down to around 9v and settles there.
At the same time the incoming feed to the booster also drops to around 9v.
Reconnected the feed from the starter to the EBL and immediately jumps to over 20v, feed into the booster also over 20v
So it seems something in the EBL is “back feeding” a high voltage to the starter battery, luckily the starter battery is not actually going higher than 12.7-ish. But TBH I’d not trust that it won’t go higher, and so is the owner of the vehicle.
He has had numerous issues with this particular motorhome and isn’t sure when this particular problem started, it may have been there since he bought it.
It seems to be a possibility that the EBL is faulty. But I’ve never known this sort of problem. Unless I need to think further out the box. He’s going to contact Apuljack to see if they have any ideas and to see if a repair is feasible.
Has this happened to anyone else, and if so what caused the problem and what was your fix?
