Thanks for that response.
Actually Lofoten gets 24 hours of Sun from about end of May until mid-August so that will help.
I am certainly going to take my time before purchasing anything, and as I mentioned above will explore how I get a second battery in.
It does have solar already, not sure what it is rated at but will look at that.
I have read varying reports about the clipper monitor mentioned above re how accurate the battery state report is but it does sound useful to work out how much power I am drawing in varous scenario (and how much is going back in via solar/driving), again I think more research required.
A quest that has always defeated me, what happens if the battery is never run down below 12.4 how many cycles do you have then?
The less you discharge the more cycles you get. (If you get less cycles for discharging more it follows you get more if you discharge less). However, I'm not sure if it works on a log scale but my belief is if you get 200 cycles at 50% D.O.D and you only discharge to half of that, then you double the total amount of cycles you get. Someone will be along soon no doubt to add their views on the subject.A quest that has always defeated me, what happens if the battery is never run down below 12.4 how many cycles do you have then?
I too have this fitted. Mine does not show what each appliance is using unless only that appliance is in use. Mine shows the total draw of all appliances receiving power from the habitation battery bank and the voltage state of the cab battery if connected to the monitor. A useful piece of kit.I was a bit paranoid on battery usage and bought the BM1 battery monitor which uses an app via Bluetooth. Advantage of it is no wiring inbtovthe hab area if the can apart from the shunt which is next to the battery.
<Broken link removed>[/URL]
I think it is a great bit if kit and allows you monitor what appliances are using what current.
Is the solar controller wired correctly?
The neg wire that should go to the battery seems to be wired to the solar panel negative. Surely the battery neg should go to the battery, with no negative wire from solar neg to batt neg terminals on the solar controller.
This looking at photo, the item without the large label.
That looks as if it is wired the way mine is - it is probably using a common negative wire for both the panels and the battery. Nothing wrong with the setup if that is the way they have done it. I'm assuming the black wire probably goes to a negative busbar where all the other negatives are also connected, including the negative wire from the solar panel.Good question. I couldn't understand why the panel and battery negatives were jumped together. I could do with working out what wires go where from the regulator.
You have lost me on this reply! The CM1 is hard wired to shunt and batteries and provides a display to an App from a bluetooth monitor. There can be a very small variation in the read out but this is normal and explained in the manual. Other users on here have confirmed they get a similar performance.I did read some review of the CM1 (directly connected - not blue tooth) and his opinion re the battery state was that it was not really accurate as they drift off over a period of time.
Can you explain what you mean by Solar Controller and Solar Regulator ? Are they not one and the same ? do you have more than one fitted ?Trying to work out what the lights on the Solar controller and regulator mean. The photo was taken this morning aaround 11ish and although overast wouldn't I expect the panel to be providing somethin
I found the controller manual on t'internet and its seems that mine is indicating that the panel is not supplying any power (charge light is off and that the battery has low capacity.
Another nail in the coffin for the battery I think.
I can't find a regulator manual so am uncertain wht the green and orange lights mean.
I will try and find the link that I was looking at.You have lost me on this reply! The CM1 is hard wired to shunt and batteries and provides a display to an App from a bluetooth monitor. There can be a very small variation in the read out but this is normal and explained in the manual. Other users on here have confirmed they get a similar performance.
OK after looking at it again, I agree the controller is indicating no charge is being received from the solar panel. This may be a fuse, or simply not enough light. If the picture was taken during the day and the panel exposed to daylight, I would expect this light to be on. Question, have you ever seen it on in the past ! (The reason I ask is that the connections to a S.P. controller should be battery first (so controller know what voltage system is) then panel afterwards. Other than that, it is either a fuse or a broken/loose connection. Battery is showing >75% charge state so assume on board charger is working OK.Tis might help. My interpretation of the lights is a charge is being received from the solar panel and indicating 75% charge.
Yes, I downloaded an english only version of this.Tis might help. My interpretation of the lights is a charge is being received from the solar panel and indicating 75% charge.
OK thanks for that! I'm at a loss too as to what it does? On my set up I only have a MPPT regulator (or controll, depending on what you want to call it) between the Solar Panel and battery connection.Sorry - the box on the left is the controller (according to the manual I googled it is a "Solar Charge Controller") the one on the right is also controller, I got my Italian and English mixed up a bit.
i.e. 'regolatore di carica per pann fotovoltaica' is translated to 'charge controller for photovoltaic panels'
The RHS box seems to have a heat sink attached but I have no idea of how it works with the Phocos (which is what I presume it is doing)
I agree ! Maybe time to get out the Volt meter and do a check- in daylight !Yes, I downloaded an english only version of this.
I think the top LED should be lit if a charge is being received from the panel though.
5-6 amps at full chat if you have the CP Plus controller less than one amp once up to temp.It's a Truma Combiu, don't think it will run with the fan off. However if you can get the temperature setting right the fan seems to go into a "low blow" state - which I am assuming will use less power.
Have you looked at page 28 of that manual? It says the positive terminals of the solar and battery connections are connected together internally and both positive feeds should be earthed to the chassis! This suggests the controller is designed for a positive earth vehicle. If the OP's vehicle is the much more common negative earth then it isn't surprising this setup isn't working very well.Tis might help. My interpretation of the lights is a charge is being received from the solar panel and indicating 75% charge.
CP Plus controller?5-6 amps at full chat if you have the CP Plus controller less than one amp once up to temp.
The digital one, it controls the fan speed accurately than the older Classic controler.CP Plus controller?
It should still work, as a shunt type solar controller brings the solar voltage down to the battery voltage but it isn't very efficient.
The above doesn't explain the complete lack of charge but a better controller will do no harm.
Ah, unlikely on a 2004 model I think.The digital one, it controls the fan speed accurately than the older Classic controler.
