Woks work as well.Can I jump on this thread, please? I have a single induction hob at home and use Le Creuset pans on it. They're too heavy to take in the MH, so what other pans could I use on it, please?
We keep ours in a laptop bag, one of the padded sleeve type ones, works a treat.Can you store a single portable induction hob on its side? Thanks
There are many grades of stainless steel and some grades do not have enough iron content to be magnetic.I have a stainless steel pan but it won't work on it
So some pans are probably made using a grade that is non magnetic.
See https://www.thyssenkrupp-materials.co.uk/is-stainless-steel-magnetic
You don't need a new set of pans you can buy an adaptor plate off eBay or Amazon for about a tenner then all pans will work.Thank you! I had no idea about that!! My husband won't thank you, though......I now need some magnetic SS pans!!!!
I would think that totally destroys the whole concept and benefits of induction......You don't need a new set of pans you can buy an adaptor plate off eBay or Amazon for about a tenner then all pans will work.
Not very efficient though - turns it into an ordinary hotplate which may cause issues if too hot. I threw ours in the bin and simply got a couple of pansReally? WOW!! I never knew that. I'll check it out. Thanks!!!
On the Le Voyageur it simply sat on top of the glass of the hob (double induction hob) - the rubber feet kept it clear.Just bought one. Can you use them on top of the hob glass lid. I suspect there must be a minimum air gap between the magnet and base in the hob, but not sure how much this needs to be if this will induce heat in the hob burners or pan grills.
Nothing in the instructions
I have read about using a wooden chopping board underneath
Yes I have for many years in a old computer bag.Can you store a single portable induction hob on its side? Thanks
best place to store an Induction hob.. ?
In the kitchen at home, along with the Remoska, Air fryer, Toaster, Kettle, Slow Cooker, Microwave, Blender, .. blah blah blah .. some vans must look like Curry's electrical store..
40+ years camping and motorhoming with a gas hob .. and have never wanted or needed any 240v appliances to knock up a good meal... and I don't need a £3k off-grid power station or an EHU to do it
I'll get me hat ..
just keep it simple and your problems will also be simple .
