Disconnect/Unplug it from mains.If fridge is on 12v when I turn off I get error codes .I'd like it to auto change between 12v and gas but not mains
I'd still get errors though?Disconnect/Unplug it from mains.
Turn off the fridge MCB if that's all it powers.
Thetford auto and manual.What fridge is it?
Can you not switch it from auto to manual ehu selection
Then there's a fault on the auto select.I'd still get errors though?
Best options then is have manual 12v which we then need to change to off or gas when stoppedThen there's a fault on the auto select.
Auto select is.....
12v yes/no....if no change to mains
Mains yes/no....if no change to gas
Gas yes/no....if no change to 12v
12v yes/no....if no it keeps rotating until there is a power source.
Just ignore the error codes if the fridge still works.
YesI assume your gas is switched on before you turn the engine off?
Is there a way round this?
If the inverter is connected to the vans sockets and fridge via the mains consumer unit how to separate the fridge power?Rewire the fridge mains connection direct to the the consumer unit so it's not connected to the inverter output, that's what I did on mine.
If it's in a 3 pin socket, unplug it which is what I said in post 4.how to separate the fridge power?
If you need to ask, then you probably need an electrician to do it safely.How to separate the fridge power?
I'll have a look and see where the fridge is wired intoIf it's in a 3 pin socket, unplug it which is what I said in post 4.
If it's hard wired to the socket circuit move it to the water heater or similar in the fuse box.
Easier than thought. Fridge, 12v charger, water heater, all on same mcb so only need to turn this off while travelling or off grid.If it's in a 3 pin socket, unplug it which is what I said in post 4.
Only thinking aloud, I'm quite competentIf you need to ask, then you probably need an electrician to do it safely.
It may well depend on the quality of the job done by the person who wired it up.
Unlikely to have been Autotrail.
