- Sep 24, 2024
- 1
- 1
- Peugeot Boxer Elldis
The same problem has happened after 2 years. Van started then stopped after 30/40 seconds. Last time the garage changed the fuel cut off and swapped some relays about. Does anyone have a diagram of the relays. The relays on this van are under the glove box which requires taking the panel off under the glove boxes No access through the fuses. Just wanted to check it’s not just a sticking relay
