Depends on budget, I have one of these and it has good optics and as it is a GoTo or computerised machine you can hook it up to a laptop or just use the hand controller.small enough to take away in the Car or MoHo but big enough.As the title. Total newbie thinking of doing a bit of star gazing and after some info on a half decentTelescope with a stand and any other info
Ta
Should add you may want to go along to an astronomy club first as they will often have a range of instruments and you can decide what you want to get from there.As the title. Total newbie thinking of doing a bit of star gazing and after some info on a half decentTelescope with a stand and any other info
Ta
But you didn’t answer his question ? ‘What telescope to buy?’You need to be checking out Mars and Venus over the next fortnight as they will be in opposition to the Sun Moon and Earth, check out the Southern Hemisphere either side of midnight over the next two weeks. Mars should appear as a large pinkish disc and you should be able to see the Northern Pole as aa white, icy, cap. I know, I know, Russ your sooo knowledgeable! Hah! Sorrel! Just read “The Times” this afternoon! But hey! Fill your boots people!
(Opposition means that planets/suns/moons etc. are lined up in a straight line!)
Oh! Oh! SHMBO is accusing me of being a boring b**tard!!
Must Dash!!
Cheers!
Russ
If thinking of selling could you pm a price please but think it could be more than I need at the moment. ThanksSWMBO has Meade ETX-LS you tell it you want to look a Saturn for instance and it finds Saturn for you, I think you can also view it via a p.c. (That may be wrong) it cost me a packet and she only used it once or twice.
If your interested I‘ll ask her if she wants to sell it
For the circumstances you describe, a good pair of astronomical binoculars will give better performance and be more useful than a telescope.Thanks again, the idea about a good'ish Telescope is because I'm off to Spain for a few months soon and you get a good view of the star's from the balcony so joining a club is out at the moment. So a good entry level telescope is what I'm thinking of maybe something like this and see if I get the bug.View attachment 428792
Thanks for the replys
This is why I have one of these its equivalent to a 6" reflecting telescope but much smaller and fits in to a optic rucksack with the tripod attached highly portable quick to set up and relatively compact and just drops in to the boot of the car or MoHo, if it doesn't have a view of GPS satellites you probably are not going to see the stars ! you can also connect the mount to a computer via something like the wifi control and if you place a camera via T adapter or a dedicated imaging camera you can stay warm and toasty while the telescope is outsideFor anything more powerful, objects will pass across the field of view so fast that you will be spending all your time adjusting the telescope up or down and sideways trying to find them again, unless you have a good equatorial mount and can set it up properly, or a computerised mount. But as the latter rely on GPS and need a good field of view of the GPS satellites, I'm not sure how well that would work on a balcony. You'd also be looking at a telescope so bulky that getting it to Spain would cost an arm and a leg or be quite impractical to carry unless you're driving there.
Yes your correct star alighn is the system but you can add a gps device to it if you wish.For Celestron, I don't think their entry level/hobby Goto scopes are using GPS.
When you turn them on you align them to 2 or 3 stars. Then the scope knows where it is.
Another clue is that you need to add time & date to their scopes (first time use & battery changes?).
Dearer models of theirs and other manufacturers may use GPS
I guess it’s like anything a ‘purist’ may say that you learn more by finding planets stars etc by your self but then again just like satnavs it’s not the first 300 miles to get somewhere it’s the last 300 yards. I’d say for a beginner use a computerised mount and enjoy the sites it will help orientate the night sky.And there are lessons to learn for a beginner that computerised mounts don't give you.
Luckily I've had a manual mount for a refractor scope for >20yr & can "upgrade" to a Celestron Nexstar goto scope.
Oops. It wasn't my intention to put anyone off.The more i read the more complicated it sounds, we never managed the art of setting up a free standing satellite dish. Haha
My Celestron CPC uses Staralign, but utilises GPS to locate itself. Staralign completes the final calculations, since levelling the mount relies on a spirit level and prone to errors, however small. You can set it manually, but you need to know your exact latitude, longitude, altitude and time, then still complete the Staralign process to get good results.For Celestron, I don't think their entry level/hobby Goto scopes are using GPS.
That's good to know. The three CPC scopes I see in the current range all look fantastic.My Celestron CPC uses Staralign, but utilises GPS to locate itself. Staralign completes the final calculations, since levelling the mount relies on a spirit level and prone to errors, however small. You can set it manually, but you need to know your exact latitude, longitude, altitude and time, then still complete the Staralign process to get good results.
I think this is where I'm at. ie pretty much a novice and anything that helps with the enjoyment to begin with is a plus.I’d say for a beginner use a computerised mount and enjoy the sites it will help orientate the night sky.
Mine's quite an old one now, so whether there are extra functions on the newer models I don't know (and don't want to look in case I'm tempted, as it appears they've virtually doubled in price since I bought mine). I have periodically updated the software on it though.That's good to know. The three CPC scopes I see in the current range all look fantastic.
I'm giving my little sister my old Celestron Firstscope 80eq refractor and upgrading to a Nexstar 8 SE that had a nice discount.
That's missing a few of the CPC gadgets but they can be added later...
If you are up norf sometime you may wish to visit the Kielder Observatory, you have to book but it is worth a vist, it was cloudy when we went.....then there was a break in the cloud and the Students that were helping run the session were visibly excited as there was break in the cloud and yes we saw Saturn, they went from serious students (Phd's) to 4 year olds in about 2 seconds flat and yet they must have seen Saturn dozens of times it is so infectious.I think this is where I'm at. ie pretty much a novice and anything that helps with the enjoyment to begin with is a plus.
Ha was just typing about Kielder and yes go but book before you do as it gets busy and its limited numbers, I don't think you will be disappointedWe have said on a list of things we fancy doing is a night sky visit/talk at kielder Forest, it does look very interesting.
