- Feb 5, 2024
- 221
- 397
- Etrusco CV540 DB
I have now done the first stage of my Starlink Mini installation, which was to get it mounted on the roof.
This replaces my Gen 2 setup with something more compact and which can be left on the roof while travelling if I want. However I also want to retain the ability to deploy the dish on a tripod away from the van as I have found that essential in the past due to shading of the van roof on many campsites. The other requirement was that I wanted to use my own router but without requiring two cables to the Mini as it has separate power and network sockets and does not support POE (power over ethernet) on the network port.
I solved the single cable issue by using a POE injector running off the 12V supply in the van with a POE splitter designed for outdoor use on the back of the dish with its outputs plugged into the power and network ports on the dish. I had already used a POE injector with the Gen 2 installation but had to replace it as it output the power on the non-standard pin out arrangement used by Starlink POE enabled devices. I used a cheapish Tycon device which has industry standard pinouts and works as an injector or a splitter in conjunction with a 12V to 48V 3A converter. The LAN output from this goes to my router.
As I wanted to be able to take the dish off the roof and deploy it on the ground on a tripod as I had done with the Gen 2 I had to be able to unplug it from the POE network cable that comes up through the roof of the van so used a waterproof box housing the socket part of a waterproof RJ45 plug and socket. For ground based deployment I will make a long outdoor network cable with a similar waterproof box on the dish end for the dish to plug into. I have a similar socket inside the toilet cassette compartment which connects to the POE injector and the roof cable is routed into this space also, so it is just a matter of unplugging the roof cable from this socket and plugging in the outdoor network cable instead to change over.
The mechanical arrangements are based on using a tripod head mounted on a plate on the roof which was previously used to hold the Starvmount I used with the Gen 2 dish. This tripod head was bolted on using a Loctited 1/4 inch bolt and was locked in place with some superglue. This tripod head is identical to the one on the tripod used for ground deployment. The tripod plate which normally fits onto the underside of a camera and clamps into the tripod head was bolted onto the bottom of the pole mount which comes in the Starlink Mini kit.
To attach the tripod plate I wanted something more robust and also much cheaper than the commercially available tripod adapters so I made my own. This basically consists of a plastic disk which is a slice sawn off a 2" diameter plastic rod. I drilled a hole through the middle of this and also through the back of the Starlink pole mount, then bolted the camera plate to this using an M 8 bolt with a low profile head, after removing the original screw from the plate and enlarging the hole. I also added two screws into the sides of the disk and drilled a hole in the disk to match up with the original screw hole used for the securing knob which comes with the pole mount and which I used to bolt on the POE splitter.
This last picture shows the POE splitter mounted on the back of the dish, though not tightened down, with a bracket I made from some alloy angle. One of the waterproof glands has been removed from the splitter in this picture. On final assembly I also used some 3M double sided foam adhesive pads under the side of the splitter opposite the bracket so it is very secure.
Anyway, I hope this has been of interest to others and shows that you can use the Mini with a single cable connection.
