Squirrels (1 Viewer)
stephen haigh
5
lancashire
ci cipro
3 years
After full-timing for 3 years we have now bought a small property. Our motorhome has been parked at a c/l we have used often. Now twice over the winter a squirrel has gnawed through the fuel pipe, a costly repair. Any advice on how to solve this when the van is now not used on a daily basis, thanks
Feb 22, 2011
9,762
20,113
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Wow, antisocial squirrrls, If it's the fuel line they're targeting could you get some flexible metal trunking fitted ,?
They might decide to attack cables then.
Or you might have to find somewhere else to park.
S
stephen haigh
5
lancashire
ci cipro
3 years
Thanks for the help, the c/l owner shot 4 earlier in the week, the flexible metal trunking is an idea
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Apparently the casing on wires contains soy oil, ( who knew) which is why they're attractive to squirrels.
Found these ideas Broken Link Removed
Sympathise with you, squirrels got into a friend's roof space and did a hell of a lot of damage.
Jan 13, 2014
3,588
11,555
Leeds - Yorkshire
Little cuties and they come in a range of colours, this was on the golf course at Denia.
lol
champers
4,224
8,423
Skegness, UK
Frankia i650 FD
Since March 09
There is a resident red squirrel here at El Raco beni.. jumps from roofs to awnings ..did wonder if it could do any damage
Kath
Rosemary1
1,427
4,152
Dumfries and Galloway
Rapido A class
1 year
Blasted things - our telephone kept braking down - the BT engineer fixed it and on the report form put “damage due to squirrels chewing wire” - lasted a couple of weeks and went again. Engineer said shoot them too:whistle:
Reactions: Mel
Nov 18, 2011
11,862
42,798
Planet Earth
A van
Over 25 year's
Kath
Red are known not to be as destructive as grey's read tend to be more elusive than grey's they are rodents so require to knaw to keep there teeth short.
But tend to prefer wood like hazel birch beach chestnut apple cherry they tend to spend more time aloft in the trees and this makes them less destructive as they tend to not move across the ground.
Where the grey will explore in the undergrowth and the under side of your van and will chew almost any thing
hope this helps but there could be a someone more informed than me
bill
Feb 21, 2016
4,915
29,397
Uk
C class
Since 2017
If you want to avoid sitting around for ages with your popgun,buy a trap. Not too difficult to set up,but mind your fingers don’t get trapped in the process.
Apr 26, 2015
2,749
6,863
Ottershaw
Hymer S820
First motorhome May 2021
Mk IV fenn trap in a proper tunnel baited with peanut butter. You can get them on ebay. I had three out of my loft last year.
Jan 28, 2016
2,486
2,911
Stockport, Cheshire
Bravaria i740 AClass
Metal cage humain trap off ebay with peanut butter works trap about £15 quid i caught two and let them go miles away on way to work
Aug 18, 2011
12,129
17,991
derbys
AUTOSLEEPER SYMBOL
Try putting food out,,it may divert them from your van,,BUSBY,,
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Correct, if you trap a grey squirrel you must kill it, not release it again.
Also, you must kill it ‘humanely’.
Bustup15
1,483
3,726
Durham
Dethleffs I 7820-2
New to motorhomes 2019
We had an issue with neighbours cats using our garden to crap everywhere. Found a battery powered pir with a 'water pistol' type ejector attached. For cats we used diluting orange as they hated anything sticky on their fur. Don't know about squirrels but you could experiment with various additives? ;)
Jaws
23,830
72,329
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I used the spiral metal sheathing from a shower hose when I had a similar problem. cheap as chips and readily available
Nov 18, 2011
11,862
42,798
Planet Earth
A van
Over 25 year's
Thay must be humanly killed and not released back in to wild by law
Nice with garlic and onions slowly cooked in the oven
bill
Jan 28, 2016
2,486
2,911
Stockport, Cheshire
As much as i dislike the grey squirrel i couldnt bring myself to kill them so yes i broke the law and let them go. Hardly crime of the year! Call the police if you want probably find they are too busy with real crime
Feb 24, 2013
13,051
101,381
Bolsover, Derbyshire
Hymer S800
not long enough
Possible solution to avoid damage could be chilli powder
Saw it on a wildlife program where they added it to bird feeders, birds are unaffected by the spice but squirrels hate it
