Split charge system disable.
llion
alliance 762
I'm fitting a victron b2b charger to charge my lithium battery to a 2019 bailey alliance. Inorder to disable the split charge system, I've fitted a 80amp relay 5pin changeover relay between the BCA and the leisure battery. Would that be the correct method?
Is your relay acting as a changeover or simply a cut-off?
Im not well up on the bailey setup. But yes a relay can work in the right place to stop both batts being seen as one when igntion on.
Do you have any more info ?
