Split charge fuse/relay
Scot7169
Fiat ducato 2008
Hi all, after some help regards a charging problem.
Habitation side bad zero power, the main fuse to the leisure battery's had blown, replaced and everything works fine.
Except.....the fridge will work off 12v the leisure batteries will not charge off 12v and the rocker switch on control panel displays no sign of power on the engine battery.
This leads me to believe there is either a inline fuse from the split charger or the relays have gone??? (I'm not sparky)
My big problem is where would these be?
I have a home car C53 2008 ,quite rare but I believe it's pretty much a replica of the lunars.
For clarity the main engine fuse box is at the front of the bay on the right hand side and cab fuse box is on the driver's bottom right of steering wheel.
If anybody could point me in the right direction as to where a fuse or relays will be it would be greatly appreciated.
Thanks in advance
Solution2
It is possible that the fuse/relay you are looking for is behind a panel at the bottom of the B pillar ,behind the drivers seat .
It could also be worth checking if there are fuses in the starter battery compartment.
Solution
Thanks had a peak in there last night expecting to find a fuse panel, there were some wires but didn't investigate further will give it a better look,thanks
The wiring behind the B post panel is for the Motorhome converters to use to link with the Fiat wiring and may or may not have been used , the starter battery compartment may also have a fuses for power supplies to your PSU /control panel
Thanks again, looked in cab battery location and with the exception of one black cable coming off the earth it all looks factory, will certainly follow that but it doesn't look big enough to be a main charge cable🤷
