Depending on the size you will need 30 to 40 kgs... It ain't lightYes to space.weight not sure.
If weight is an issue then consider just taking just a spare tyre as a minimum.Yes to space.weight not sure.
We have European breakdown cover tagged on to our insurance with Comfort for around £65.Yes had thought of just taking a matching spare tyre.To save on payload.
How does that work if I get a flat in middle of France.
I am with the AA.will they be happy to take me to the garage.or is there people who can come to us to change road side.
Not much the AA (others available) can do at roadside if your tyre wrecked and you don't have a spare for them to fit.We have European breakdown cover tagged on to our insurance with Comfort for around £65.
I don't feel the need to carry a spare tyre. We do have the Fiat goo and and compressor kit.
If weight was an issue for me I would leave something else behind.... Absolutely no way would I venture out without a spare.Yes to space.weight not sure.
I had alloys and a steel spare on the last mh. It was only when I took it to my usual indie for mot that he told me I needed different wheel bolts for the spare. Which he provuded FOC.We recently bought a new motorhome which didn't come with a spare wheel.
Our motorhome has alloys, but I bought a steel rim and purchased a tyre from Kwik Fit.
The spare tyre is the same make/type as the other four.
This is important if travelling in France where I understand you cannot mix tyres of different types on the same axle.
I would not consider driving to France/Spain without having a spare wheel.
How do you check if the same bolts will do?I had alloys and a steel spare on the last mh. It was only when I took it to my usual indie for mot that he told me I needed different wheel bolts for the spare. Which he provuded FOC.
I have the Fiat CCS chassis with Fiat alloys, I bought a new steel wheel and matching tyre continental CP for £100 and can assure you the bolts from the alloys fit perfectly on the steel wheel, Mercedes van need different studs for a steel wheel.How do you check if the same bolts will do?
(I assume the best way to check is to remove a wheel and fit the spare).
They are standard Fiat alloys on a light chassis.
30 kg on a 225 75 16??It would be much easier to provide precise advice if you gave the existing size and details
already sugested.
a 15" conti on a steel wheel
