Spare steel wheel rim for sale (2)
Westbarn1
Norwich
Hymer BMC-T 600
Newbie
Sevel (Fiat/Peugeot/Citroen) steel wheel 5 x 130 PCD 6 x 16”, including OE wheel nuts (shorter than alloy wheel ones) ideal if you don’t have a spare. In good condition, no corrosion. £30 collected Norwich or plus £7.67 posted to mainland UK
I only have 2, also have a set of OE Sevel plastic wheel covers that will post separately.
Is this for the Ducati light chassis. If yes, I will buy.
i believe the light chassis is only on 15" wheels, but i could be wrong!!
Thanks. My 2019 Chausson 530 is on the Dlight chassis but comes with 16 inch wheels as standard.
Hi, haven’t a clue what the light chassis is, these are 16” wheels, if you have 16 wheels, you will need to measure your PCD this is the distance between the wheel nuts.
The light chassis is 5x118 pcd
The heavy (Maxi chassis) is 5x130 pcd
Also the hole in the middle is a slightly different size.
Doesn’t matter if they’re 15 or 16 inch the pcd is as above.
Thanks Westy. Unfortunately, Fiat don't alway stick to the above as I've got a 69 plate Chausson built on the light chassis with 16 inch wheels/5x130mm pcd.
To add to the confusion there are also two wheel stud sizes, mine has the 21 mm head with M14 thread. The studs for my previous heavy chassis motorhome wheel don't fit as they are are a larger diameter. I found this out when checking to see if the spare wheel I kept fitted!!
Nothing is ever easy!
Checked my nuts this morning, sorry bolts!
14mm x 1.5 thread, total of 63.6 mm long
The wheels have a part number stamped on the outer side, that's how I made sure I got the right one for my van.
Reactions: DJT
Number on outer side of wheel, one wheel sold to Kraken, only one left.
Well it’s definitely a Sevel wheel it’s stamped on , will have a look on inside when I get home
Only other number on inside is 235X
It is if you have 4 nuts, just measure straight through the centre to the middle of each nut and you have the larger of the pcd measurement e.g 4x100 where 4 is the number of studs and 100mm the diameter. if you’ve got 5 studs it’s the diameter if you drew a circle through the centre of every nut and measured the diameter.
