Is there anything in the vehicle manual?Thank you, but which deisil do I use in 2017 Hymer?
Colyboy 4
What do you put in now... The cheap stuff or the posh stuff.Thank you, but which deisil do I use in 2017 Hymer?
Colyboy 4
I think hose/nozzle colours vary by countryIs it still on the BLACK pumps ?
I think any engine can use the higher grade B10 in the same way an old petrol engine could use 4 or 5 star if it normally used 2 star but it wouldn't make it run any betterB7 is normal diesel as used before the new codes.
https://www.acea.be/uploads/publications/ACEA_B10_compatibility.pdf
The above link shows which vehicle can use B10 grade,which is quite a lot,but ill stick to B7 in mine.
Cheers Cris..
What engine is it ? Unless it specifically states ok on the filler for B10 don't use it. For fiats in that list it specifically states only to be used on ones with sticker.Thank you, but which deisil do I use in 2017 Hymer?
Colyboy 4
No that isn't correct. The existing dearer stuff has additives it isn't the same as B10 with 10% rubbish in it .The cheap stuff or the posh stuff.
B7 is the cheap everyday stuff
B10 is the stuff you need a mortgage for.
& yellow in France is it ?I think hose/nozzle colours vary by country
UK is black.
No the B10 is forbidden in many common rail engines due to the caking that can happen. In that list that shows vehicles most state B10 use is only on medels with a sticker on the filler. & with Fiat that rules out most. Asit does with other manufacturersI think any engine can use the higher grade B10 in the same way an old petrol engine could use 4 or 5 star if it normally used 2 star but it wouldn't make it run any better
The other way round will have serious consequences though.
The cheapest place around here , Gasexpress has a pump for diesel & a pump for petrol .No choice here. apart from an extra 5 cents of tonight for halloween so that's 1,14€Ours is 2017 euro 6 and will get the same as it gets now, the cheapest we can find. Bob.
I hate paying for fuel and on our 2 month, 11 country tour we have used super tanker loads of the evil stuff but with diesel I do always when possible use the high performance stuff. Up to 14 cents more per litre but a (small) improvement in economy. The most important thing is the extra additives that help lubricate the very expensive fuel pump and keep the lines and system clean.Ours is 2017 euro 6 and will get the same as it gets now, the cheapest we can find. Bob.
B = Bio diesel (derived from agricultural materials)Can some one explain what all the new pump labelling is meant to be in Spain?
Types of Diesel = B7 B10 XTL
Types of Petrol= E5 E10 E85
Types of Gas= H2 CNG LPG LNG
colyboy
The really cheap supermarket stuff does lack some of the quality of the main brands. Much of the advertising with fuel is complete nonsense but do remember that a fuel pump can cost over £4,000 to replace and I think that it is a wise investment to use decent fuel in your motorhome to help avoid costly problems.
Yes,supermarket fuel is rubbish.I hate paying for fuel and on our 2 month, 11 country tour we have used super tanker loads of the evil stuff but with diesel I do always when possible use the high performance stuff. Up to 14 cents more per litre but a (small) improvement in economy. The most important thing is the extra additives that help lubricate the very expensive fuel pump and keep the lines and system clean.
Yes it definitely does vary. Once when carelessly filling up in Spain I put about 10 litres of petrol into the tank with a black coloured nozzle before I noticed the label said it was petrol. The tank was empty so I decided to just fill up with diesel (60 litres) and hope for the best. Lucky for me it worked out OK.I think hose/nozzle colours vary by country
UK is black.
Except at Burton M6 Services where petrol is / was black. And don't ask me how I know.I think hose/nozzle colours vary by country
UK is black.
