Solving water mark on wall/ceiling lining! (1 Viewer)
Nov 2, 2022
350
1,262
Cumbria, UK
Hobby Optima T65 de
Too long
I have a small water mark on my ceiling from a leak which was sorted out before I purchased. Anyone one have a secret recipe to reduce/clean it off please? A friend has suggested shaving cream but wondered if there is a go to safe method.
TIA
cliffanger
5,222
35,958
Saltford
Hymer A class
Since 2013
We used elbow grease on all our upholstery (the person who bought our 690 new chose beige suedette šŸ¤·ā€ā™€ļø
Itā€™s absolutely brilliant, but youā€™de have to use it on the whole panel, as it would leave a mark where it had been used, ie. The outside panel of our drivers seat had a couple of grubby marks on, so I tried to spot clean it and it left a mark, so I did the whole panel and it was fine.
I know what I mean even if you donā€™t! :rofl:
Apr 1, 2024
247
363
Bolton
Hobby T500 LHD
Spring 2024
In a similar vein I have some staining on a roof blind that was there when I bought. I was thinking I might try spraying with diluted bleach. Does that sound like a good solution (Pun intended!)?
Apr 13, 2012
5,825
19,903
Mobilvetta Euroyacht
1996, then break 'til 2011
I used weak bleach solution in a spray bottle and citrus cleaner worked in with a paintbrush and wipe with a clean cloth.
Needed a few applications but worked fine - cover anything with old towels,use gloves and wear glasses
Apr 26, 2015
3,297
7,971
Ottershaw
Hymer S820
First motorhome May 2021
You can try a hydrogen peroxide solution, depending on the strength you buy you may wish to dilute it with distilled water. Test it on a bit that can't be seen first. It can be mixed with cream of tartar into a paste if you need an abrasive but try it without first.
Jan 9, 2014
190
359
Scotland
Rapido 803F
Since 2006
Sure I read somewhere to use white vinegar then sponge off with a damp cloth. Donā€™t quote me, but Google it, perhaps?
icantremember
8,451
18,095
Near to Watton in Norfolk
Hymer T-SL668
since 2005
TIA
Depends on the material & finish ... on a previous motorhome we had a water stain on a wall panel which was ply wallboard with wallpaper covering. The cure was to firstly cover the area with an oil based primer and then to sponge stipple the pattern with matt emulsion colour mixed to suit.
HKF
2,913
5,599
The Charente, France
Benimar Europe 740
Since August 2021
TIA
I also have some staining on our ceiling, from a leak. The ceiling is white and the staining is a blueish colour. The ceiling looks like it has a papery finish and I'm too scared to try anything on it, in case it looks even worse. Using something like bleach on something white can actually end up turning it yellow, so I daren't try that at all. I'm watching this thread, in case anyone has a safe answer :)
Apr 26, 2015
3,297
7,971
Ottershaw
Hymer S820
As I mentioned, hydrogen peroxide works well, I have a water stain on my headlining, some Hydrogen peroxide and a small stiff brush removed it, in the after photo it's still damp but the stain has pretty much gone, I'll give it another go if anything remains once it's dry tomorrow.
Jul 29, 2013
9,181
20,430
Salisbury
Hymer B678DL A class
since 2011
A little neat washing up liquid then sponge out with damp spongešŸ˜Š
