Solenoid gas valve stuck after storage
Eastbourne East Sussex
Hymer low profile
Since 1972
I found a useful hint on youtube, which worked brilliantly for me so thought I would share it.
My fridge gas valve failed to open after several months of non use, which is a very common problem. It can be fixed by vibrating the valve in some way to unstick it, but the novel (to me anyway) way was to use a cordless hammer drill, set to hammer but with no bit in it to shake it loose.
I improved on the original by using a wooden drawer knob that I had lying about, held in the chuck to avoid metal to metal contact that I thought might do some damage. SWMBO inside the van to switch fridge to gas, a quick brrrrrr from me against the solenoid gas valve and Robert was your fathers brother. All working again.
Boiling water poured on the body of the valve is also worth a try?
sorry for the late reply. whereabouts is the relevant valve to target?!
On the back of the fridge, usually easily accessible through the lower vent. Just follow the thin gas pipe back from the jet and you will find a largish metal object with gas and electric connections. That it.
