It will only produce 12volts..Does it work in place of EHU -ie operate sockets?
Ta
Thanks all - suspected same. Presume solar will be ok all year round to keep fridge, tracker and router working without resorting to EHU at home?
And, if possible, video the intro with your phone so that you can listen/watch again whenever you need to.I would imagine whoever is selling you a new (not yet registered) van will go through all these things with you. Make the most of the intro and ask whatever you need to know there as well.
Gas in exchange cylinders (e.g. Calor) will be at least double the cost of having refillable cylinders (e.g. Gaslow).. I'm guessing though that the cost of gas to power a fridge would be minimal
Happy using someone else's electric on EHU and not planning on wild camping off grid other than day trips. Main query is whether the solar would be enough to power fridge, tracker and router without EHU at homeA 100W panel is just going to keep your lights and water pump going. If you want serious EHU free, off-grid vanning using things like microwaves, then you need to be looking at 3-400W of solar, 200AH of lithium, a 1500-2000W Inverter and if a new van then almost certainly a B2B. Not cheap but cost effective over the longer term.
One 100w panel? NO. It will struggle to keep a router going trough the winter.Happy using someone else's electric on EHU and not planning on wild camping off grid other than day trips. Main query is whether the solar would be enough to power fridge, tracker and router without EHU at home
