We have a Roller Team 2021 Zefiro on a Transit chassis. The MH is stored outside in full sun with no easy access to mains hook-up. After the AGM vehicle battery (VB) flattened completely in storage I installed a VanBitz Battery Master. I had hoped this + 100w solar panel would keep the VB fully charged at least in the sunnier months. While we were away for 3 weeks in February the VB completely flattened again (I should have charged up the VB before the trip). This summer the VB voltage has slowly drifted down and required a jump start around 6/7/23 - see battery history chart from Phantom app. Shortly after we did a 200 mile trip to Cornwall with the VB voltage up to 13v but on our return it quickly fell to 12.3 and has drifted slowly down since then. We had the VB checked by the dealer who reported it was fine.
My questions are:
1. Is a 100w solar panel and a Battery Master insufficient to keep VB voltage steady in July? I believe the Battery Master only delivers a 1A trickle charge. Perhaps this is not enough for the current drain in modern vehicle electrics?
2. What VB voltage should I see in summer stored outdoors? It dropped almost immediately to 12.3 on return from our short trip in mid July, which seems low. The leisure battery voltage is maintained at north of 13v by the solar panel.
3. Does all this indicate a problem with excessive current drain from the VB when not in use, or damage to the AGM VB not revealed by the main dealer check?
Thanks in anticipation.
My questions are:
