Solar Trickle Charger?
gerstlauer
Van Conversion
2 years
Hi there,
Can anyone recommend me a small 5-10w trickle charger to sit on the dashboard in my Citroen Relay (110ah battery).
All of the ones I can find on Amazon are just panels, and don't seem to have much in the way of overcharge protection. Many thanks.
You won't need over charge protection until you get to the bigger panels so a 10w panel straight to the battery will be fine ( especially in the UK)
I'm reading that a lot, and I understand it is a small current, but say I've just done a huge drive, my battery is full, and I'm in a sunny country... Surely putting an unregulated supply in wouldn't be a good thing? I'm not sure?
You will struggle to see more than 0.5amp under ideal conditions so at worst your battery will see a very slight increase in temp which will cool down to ambient at the first sign of a cloud.
The natural self-discharge of the battery will take care of the charge from a very small solar panel.
I have been told nunmerous times get at least 20watt as top up charger - it wont't charge but "maintains". Plus a controller over 20watt is really cheap anyway for an angine battery.
I ued to use a couple of suitcase style solar panels to keep the batteries topped up, one for the engine and another for the hab battery. As I could get them facing the sun for the hours around mid-day they produced around 1 amp each which was enough to keep the batteries from fully discharging although they always needed a boost when I could get round to starting up. These days I use a roof-mounted solar panel and a battery master and have never needed anything else.
Just a note - if you intend using the dash sockets to plug the chargers into remember that on most they're ignition controlled so you'll have to do a little jiggery pokery with the wiring.
My unregulated 5w solar panel did this after several days sunshine..
14.7v all day ? now I know it's only a small current, especially when in the windscreen, but it can't be doing the battery any good. I've unplugged it now.
The thing is if you get a regulator for a tiny panel, the panel may use more power than the solar produces in winter. I would look at maybe a 40w panel and a regulator with low power consumption, it usually specifies it in the description. ?
