- Apr 7, 2022
- 1,014
- 3,664
- Chausson Welcome 70
Hi,
My Solar system appears to have stopped working, I have a Multisol P6 230w panel and a cheap and nasty T20 MPPT controller, my initial reaction was that the controller had packed up, which I wasn't too upset about as it really needed replacing with something better. But it is looking like the solar panel its self.
According to the specs the open circuit voltage should be 37.1v, I am getting about 35v, so I am happy about that, but the short circuit current should be about 8A, but I am only reading about 240mA, I have some inline connectors on the roof, so I disconnected them and measured it again there, same results.
Now I presume that there are more connectors on the back of the panel, but I cannot get to them without removing the panel, this is where the next problem starts.
The panel has 6 mounting brackets, I presume that whoever fitted it, bolted the brackets to the panel, then used mastic to glue the whole thing down, in its self I have no problem with that, but the idiot that did it just used nuts and bolts, so there is no way I can get any sort of tool onto the rear of the bolts to hold them while they are undone.
So the questions are:
Has anyone any suggestions of something I might be doing wrong or missed while testing the panel? (I did try two different meters)
How I might go about ungluing the panel, or a suggestion on how I might hold the rear of the bolts?
If I get the panel off, is there anything that might be repairable on the back of the panel?
Thanks in advance.
Dave
Thanks in advance.
Dave
