Quick question, what's the best I can expect from a 175watt panel at midday toady in full sun? Mine seemed to be putting 5.7amps back into my batteries, is that about right?
Depends how discharged your battery is.Quick question, what's the best I can expect from a 175watt panel at midday toady in full sun? Mine seemed to be putting 5.7amps back into my batteries, is that about right?
Midday today, after using my inverter for a few minutes to boil a kettle I was getting up to 8.2a out of my 140w panel via a votronic mppt regulatorQuick question, what's the best I can expect from a 175watt panel at midday toady in full sun? Mine seemed to be putting 5.7amps back into my batteries, is that about right?
It's in the constant voltage (absorption) stage then. The charging current steadily decreases until the charger decides the battery is full.My (not very reliable) meter was showing 85% remaining of my 220amps and had already been charging at a lower rate due to tree shadow for a couple of hours already.
Is that a built in panel meter or have you coupled something up yourselfI have a meter attached to the Votronic MPPT controller showing volts and current. (charging 120 Ah Lithium with 95% SoC at the time)
It showed 5.7 amps from 2x100watt panels in today's slightly hazy sun. Which confirms my view that the 100watt panels put on by the dealer were not the best available. (But, they do work so Hey-Ho)
