Johnra
Now testing a home installed 170W Sunpower solar panel on a Blue Evolution 540 pop top. We have only had the van for three months (we are newbies so still learning a great deal) and don't want to mess the van up in any way.
The routing of the cables to the solar panel was 'interesting' - from under the passenger seat where the PV Logic MPPT controller is mounted, via the electrics floor box then behind the loo, over the rear wheel casing, up the nearside rear pillar, out through the steel top (but inside the pop-top edge), up the pantograph support and through the lid to the panel.
The PV Logic MPPT controller then feeds the the two 95Ah AGM habitation batteries and later the van battery via the solar socket on Schaudt EBL30 van controller. The charging (and configurable) information is shown on an App on the phone giving accurate voltages and currents.
Originally wanted to fit a Victron controller, but they don't make a double output MPPT controller and a friend had a PV Logic controller on his Ayres Rock van.
Hope it will keep all three batteries fully charged over the winter, and also the fridge running with no hook-up in the summer.
So far so good, on a dark wet winter day with no sun it seems to be giving out enough power to raise all the battery voltages to over 13v. Time will tell.
If I have made any mistakes then please point them out. The solar panel has a circuit breaker and the two battery outputs are fused.
The panel is bonded on with Sikaflex around the edge and in the middle.
John
John
