Hi Forum,
Looking for some help and advice please.
I have a Sunlight Cliffe 540 which I bought this year. I go to a lot of music festivals and want to be able to power my Fridge off grid for 5 days, and ideally 7 (for Glastonbury).
The fridge in the Sunlight is electric, not gas.
The van came with a portable Renology folding suitcase solar panel which has the solar charger built into it which I connect to the van via an outside SAE socket. I’m not sure but think the panel is 100 watt judging by the size. I used the solar panel over the summer and it kept the battery reasonably well topped up. The problem is I don’t want to leave the panel unattended so want to add a Solar Panel to my roof so I can continue to charge when i’m away from the van. There’s a lot of roof vents on the Cliffe, but there is enough space to fit a Renology fixed 200 Watt panel.
I have also bought a Jackery Explorer Solar generator and this comes with it’s own 200 watt portable Solar Panel. The plan is to use the Jackery to recharge devices like phones/ipads and to power other kitchen stuff such as an air fryer. This will mean that the leisure battery is primarily powering the fridge and van lights. I could in emergencies connect the Jackery to the EHU on the side of the van, but again wouldn’t be able to leave the Jackery inattended.
My thoughts are as follows
I fit a fixed 200 watts panel to the roof, and connect via a new MPPT solar controller fitted inside the van to the leisure battery.
Ideally, i’d like to be able to also plug in the 200 watt portable suicase to give the battery an extra boost, via the existing external SAE. This panel doesn’t have it’s own built in MPPT. That way when i’m in the camp, I can get 400 watt of solar.
Has anyone done this and does this sound like the right way to go?
many thanks
many thanks
