Solar panel from them days
L'Isle Jourdain, 86150 France
C Class I think
Just bought an Eriba FT 580
Probably a question without an answer but anyway, the solar panel on our MH dates from 2002. It is 120cm by 53cm. It has been riveted on to the mounting so I can't easily get under it. Even if I could, the label looks like it parted company a while back. Any thoughts on what wattage it is likely to be?
Given size and age probably 100 w .....if it's working don't worry about it .....you can always add more but if you are managing ?
I removed the panel off my 2001 Hymer and it’s the same physical size as the new 100watt panels but when removed the label said it as 65 watt and that’s when I was made.
Probably a Polly rather than a Monocrystalline.
