Hi all, any recommendations for cable trunking for the roof.
Thanks, Mike.
Thanks, Mike.
That is a total bodge usually done when you get a dealer to fit the panel. In hot sun the cable tie bases will soon be loose and cables will be flapping about.I'm not sure if its helpful but trunking for solar panel cables are not normally fitted to new motorhomes nowadays. They use a gland like the link below when entering the van and the cable is attached to the roof for its short journey with cable supports and 3M sticky pads.
Amazon product ASIN B01LZ4KZ27
And we know why....I'm sorry Lenny but this is how the Swift Group have been wiring up their solar panels on new motorhomes for a few years now.
QED total bodged hate to think how the rest of the van is built.I'm sorry Lenny but this is how the Swift Group have been wiring up their solar panels on new motorhomes for a few years now.
You are not alone - just reporting as it is.
My FamilyScout is gold and my Campscout is blue so can't get trunking to match anyway and I ain't spray painting it to match!Unless you use white cable ( on a white roof) it will look naff.
Also looks mucky after a while as dirt & much collect around the cables, also makes washing the roof akward.
I'm proud of my nice tidy roof.
Then why bother with anything.... Simply sikaflex the cable directly to the roof.Why DO you need to enclose the cable in trunking though ... when I installed the solar panel on our FamilyScout I didn't use any, I actually had some large cable clips (as you'd use for household cable runs), I placed the cable where I wanted it to run held in position by tape, removed the nail from the cable clips and Sikaflexed the clips over the cable to the roof ... in 3 years they haven't budged! It meant I didn't have to mess about cutting and sticking down trunking and could bend the cable to where it best fitted/ran to the inlet which is just a simple one as shown in image 2 below (well sealed with Sikaflex).
I did try that but it is a b*gger to do it without getting coated in the stuff yourself or spread it around the van roof when the flipping cable moves about before you've got it taped down ... ask me how I know!Then why bother with anything.... Simply sikaflex the cable directly to the roof.
Line of sika, lay cable on and a bit of tape to hold, until cured, as you go along.I did try that but it is a b*gger to do it without getting coated in the stuff yourself or spread it around the van roof when the flipping cable moves about before you've got it taped down ... ask me how I know!
Some people are Sooooooo lazyMy FamilyScout is gold and my Campscout is blue so can't get trunking to match anyway and I ain't spray painting it to match!
Easy on a flat roof but on a corrugated camper one not quite so easy!Line of sika, lay cable on and a bit of tape to hold, until cured, as you go along.
I'll be having a play this week so will decide when I'm up there what to do ... I might just stick to the clip method and knock the ruddy nails in!
Make sure the nails are long enough so you can bend them over on the inside.Easy on a flat roof but on a corrugated camper one not quite so easy!
That would be a bodge.Then why bother with anything.... Simply sikaflex the cable directly to the roof.
I hate to see cable runs or pipework not installed correctly , even when it's out of sight.. I once had an apprentice who thought it was ok to run cables and pipes in any old fashion simply because they were in a void and no one would ever see them.. how wrong he was.. I SAW them and made him rip it out and start again.. lesson learned..
Do it once, do it correctly, use mini trunking
