Hi, my current set up is standard 2021 Adria Twin with solar (120w I think), a Sun Control SC300M MPPT and I added a Fogstar 280ah lithium battery earlier this year.
At present the battery is sitting at 65% with a voltage of 13.1 and not being charged. I suspected it was not charging while in France but using fridge etc I was never sure. At home I can test with no 12v loads. The MPPT voltage on GRD to PF1 (solar panel) fluctuates between 13v and 18v. GRD to +BS(hab) is 13.1 and +BM(cab) is 13.1 when tested.
Checking the Sun Control instructions it states that the service battery will charge “if the voltage supplied by the panel is higher than that of the battery. I'm assuming that the controller is moderating the voltage to 13.1v then as that matches the battery it’s not charging, however I want it to charge to 100%. On the page detailing “Charging Curves” LiFEPO4 (I have the jumpers set to this) states Phase 2 constant at 14.6v and Phase 4 maintenance at 13.7v.
Any ideas how I resolve this? My knowledge of electrics is a basic so I’m probably missing something obvious to others.
