Hi all. I am after a bit of advice. I have recently bought an old Hymer. It is a 1997 Hymer S630 (Merc). Having never had any electronics experience I am a bit unsure.
I would like to replace the 100w solar panel with 2 new 200w (each) panels and bi-pass the EBL (EBL 105-3). If I connect these to a new Votronic MPP 440 controller and then directly to the leisure battery (and not use the solar port on the EBL block "D) but leave everything else on the EBL as before, am I going to cause any issues or are there other things that will need to be done?
Later on, I will probs need to install a B2B charger and disable the split relay in the EBL, look at upgrading the battery to a LiFePO4, but for the time being, I am happy to leave the VSR as is (if that is not a problem). Baby steps!!
