Solar charging starter battery (1 Viewer)
Mr bean
32
17
Dethleffs 4-Travel.
Since 2006
Hi all, I’ve got a little 4.8W solar panel just to keep my batteries topped up, it plugs in to the van 2016 Dethleffs 4 Travel through the engines diagnostic plug and the starter battery is showing 13v the leisure battery is only 12.5v is this because of the way it’s connected!!
golly
2,059
73,916
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
I would imagine that it is because there is no direct connection to the leisure batteries from the diagnostic plug, unlike when charging via the on board charger. But there again "I know nothing" :giggler:
Mr bean
Mr bean
32
17
Dethleffs 4-Travel.
Since 2006
Thanks golly, I thought that might be the case. I definitely know nothing!!!
Mr bean
Mr bean
32
17
Dethleffs 4-Travel.
Since 2006
Thanks chaser! Looks like I’ll have to go full solar.
Apr 20, 2020
1,185
2,647
Northern Ireland.
Adria Compact SC.
Since 2017
I am no expert but is a 4.8W panel going to keep a battery topped up?
I would think that during the winter it will be doing nothing.
43,765
52,828
Just bin the panel.....4.8watt is neither use nor ornament.
Maybe in North Africa with the sun directly overhead the most it will put out is around 300 milliamps (⅓amp)...the batteries natural drain plus parasitic loads will exceed that.
You want at least a 30watt panel and an endless clear day to make a difference.
The starter battery would be showing 14v plus if it was doing anything useful.
Mr bean
Mr bean
32
17
Dethleffs 4-Travel.
Since 2006
Definitely puts something in, I’m in Spain at the moment so getting plenty of sun. But think I need to do it properly and get 125W solar panel and mppt controller.
Stealaway
8,496
11,546
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
I think your money would be better spent on two solar panels and a regular dual battery solar controller
