Keithwill
Recently bought a Rimor Katamarano 95Plus 2015 Renault Master coachbuilt. The arscillici Control unit that controls all the habitation electrics 230v and 12v and I assume the charging of the leisure battery has no provision for adding solar charging. A Solar panel has been fitted to a cheap PWM controller and connected direct to the leisure battery. This does charge the battery at 14v and mostly less than 2 amps unless in direct overhead sun. Question is will the charging via alternator see the 14v output from the solar into the battery and therefore a charge is not needed. I disconnect the supply to the solar controller when driving and re-connect when sited to be sure The Leisure battery gets a decent charge. The solar controller has been fitted up close to the roofline midway on an internal partition, and cables run down in a panel then under the floor. Modifying the wiring layout would be a nightmare.
Any advice appreciated.
KW
KW
