You need to use active charcoal pellets.A friend told me last week that the Thetford filters can be refilled. His advice was to open the filter and empty out the contents and then refill with kitty litter.
I have not tried it yet so cannot verify whether it works or not.
When I modded mine to a roof vent I used the underfloor outlet to couple it up so no pipe to faff about with.A big plus is no faffing about connecting and disconnecting a pipe to your cassette as you have to do with a SOG.
Like this:-Thanks for the feedback and suggestions
How do you go from underfloor to roof vent are you fitting a pipe of some sort up the wall of toilet space?
Make your own, pretty cheaply
Yes this. I use aquarium activated charcoal pellets, then a bit of duct tape to hold the top back on.You need to use active charcoal pellets.
Here is what I did.Yes this. I use aquarium activated charcoal pellets, then a bit of duct tape to hold the top back on.
hi i have the same system ,,filter been in for well over a year, and still seems to work ,,,change it every 4 weeks ,,ha.. just like you should change your bed every 5/7 years or something ,, ok ,,dont think it too loud ,,might change the filter ,,maybe it should be 4 years ,,not 4 weeks ,,I fitted the Thetford extractor 4 years ago and it's still on the same filter which has no noticeable pong outside the van after all this time.
As for noise, not that noisy, but so what, as it's not used overnight and to date we have not needed a dump during the night.
Ours works well and well happy with it.![]()
