skylinersi
<<<<<<< we use furbert…….
All a waste of time. The windows are the weak point. Unless you put bars on them.??
true, but regardless of what you do, if they want it / in, they'll manage
Yes, and they’ll do a lot more damage in the process the more stuff you put in their way.
You can leave yours next to mine, with the keys in the ignition if you like. Let the thieves take the path of least resistanceYes, and they’ll do a lot more damage in the process the more stuff you put in their way.
All a waste of time. The windows are the week point unless you put bar on them.?
that's why I rarely leave it unattended.Depends on whether they want to steal your van or just break in and ransack it. The latter is more likely 000s of kms from home.
But the only way in to mine is breaking the cab windows. then they have to climb in/out through them as they can't unlock any of the doors- & as I said earlier I want to catch them i'm not interested in a bit of damage.All a waste of time. The windows are the weak point. Unless you put bars on them.??
No, that’s why you have insurance.
In my case (AXA policy) up to £5k of personal belongings - fire, theft or attempted theft.Does the insurance usually include all the MH contents?
The hidden fuel pump switch sounds very useful. How do you fit one ... or where do I get one fitted?Keep mine simple as its a self built--Disklock on s/wheel (visual deterrent) and door deadlocks /hidden fuel pump switch. Simple/effective and cheap.
Break into the feed to pump and take through a hidden switch (auto electrician if you cant do it ?)The hidden fuel pump switch sounds very useful. How do you fit one ... or where do I get one fitted?
I can't believe you should go to such extreme measures I have just removed the engine battery ,No thief is going to bring a replacement battery with them.I suppose it depends on how much you value your van and how much you are attached to it that determines the level of security you use to protect it. If the latest model MHs have keyless entry similar to my car then you are probably aware how venerable it is. I have become quite attached to my old MH and it would piss me off to lose it so as I wont be on the road for a while I'm looking at ways to increase security. At the moment it has a Sigma alarm system, a steering wheel lock, a heavy duty chain secured to the axel, the habitational door is secured with a steel bar from the inside, the windows have pins through the catches. Its not possible to fit a security post but I'm thinking of fitting wheel clamps. I was wondering if there is a simple way to immobilizing the engine, appreciate any suggestions.
The might think it is a xmas cakeHow about having a secret switch in the cab that de-activates a pop up neon sign on the roof saying "This vehicle is stolen please inform the police" Well, I thought it was a good idea.
No motorhomes fit in a shipping container.Ours is parked at back of house, is one of few 'A' Class in the country, is RHD, and will not fit in a shipping container, so is very easily identifiable in this country, and it is a minimum of 100km to a border.
In addition there is an Alsatian and two Policemen living in the flat below. The iron gate bolt squeaks.
I just hope the above takes care of the situation.
Geoff
I cannot believe how over the top all that lot is,So over the top as to be paranoid.Pedal lock, steering lock, alarm, tracker, always dead locked. When away from house the above + 1/2" stainless stell locking pins through front 'B' pillars into door frame rear doors, dead lock bolts internally top & bottom & rear doors & side door have milenco external door locks. Only way in to the van is through the side door. Fortunately the only actual door lock for a key is on the drivers door the passenger door requires unlocking with a remote & the rear doors are separate system using remote only.
But it doesn't pay you for the inconvenience ,hire of another vehicle, loss of use of vehhicle until it is replaced, cost of travelling 000's of kms finding another, etc;etc;
Mine isn't protected to prevent theft but to may gain the extra seconds that I might return ,catch them in the act & can then torture & kill them, for days.
At least you would get it back when they realisedEasy answer, buy an Elddis. Even the dumbest criminal would have more sense than to nick that.
My old bus is coming up to her 13th birthday which makes her 67 years younger than me so although I thought about removing the engine battery I doubt I'd have the strength to lift it. Thanks for the offer of your security post but like I said Its not possible to fit one.I can't believe you should go to such extreme measures I have just removed the engine battery ,No thief is going to bring a replacement battery with them.
I have an unwanted security post if you want it.
